Status
Not open for further replies.
I have an 03 Impala and need to know if there's a way to lock my high beams into the on position. The high beams work when turn signal lever is pulled back towards me, but I can't get them to lock in position and remain on...suggestions??
Typically, they "lock" into position when you push the arm forward (instead of back). If the arm doesn't lock into place, then I suspect something hardware-wise is broken or worn out...
Is there anyway to program your High Beams to come on with your automatic lights instead of your low beams?
Status
