Status
Not open for further replies.
I have an 03 Impala and need to know if there's a way to lock my high beams into the on position. The high beams work when turn signal lever is pulled back towards me, but I can't get them to lock in position and remain on...suggestions??
IIRC if you pull the lever towards you thats a "quick flash" what you do is push the lever towards the dash and that is when they will be on all the time.
I read a few older posts and pushing the lever towards the dash was the common response and seems to be pretty common in most cars...oddly enough in the 03 impala this doesn't work, only pulling towards you. Let me ask this question, Is there anyway to program your High Beams to come on with your automatic lights instead of your low beams?
Status
