Every user of Canon Inject printer will find the Canon printer error B200 Error code at the printer, the cause of error in this printer is very verity but in this printer main Error is B200. The cause of B200 Error is the printheads overheating.
For the Error code B200, Canon technicians recommend to users some general fixes for this difficulty.
Solution is:
• Turn OFF the printer.
• Unplug the printer from the authority source.
• Open the printer cover then reveal the ink cartridges.
• Take away the printhead from the printer be careful.
• Clean the Printhead along with the Ink Cartridges.
• Clean the contact pads in the printer with a contact cleaner or a good pencil eraser.
• Re-install the printhead again.
• Re-install the ink cartridges after that before powering up the printer.
• Run the “Auto Head Alignment” for testing the printer.
Interesting. :dunno:
IP goes to India. Is the help desk having a slow day?:WTF:
dude, thank you so much for such a useful guide. I had a Canon printer and I constantly encountered various problems when working with it. Once the printer refused to see the cartridge and I could not understand what the problem was. I used very high-quality cartridges, but all the less, the printer did not see them and did not print. I tried more than 5 different cartridges from different online stores and only cartridges from mrdepot worked fine and it just saved me. So if someone faced the same problem, then I suggested you a great solution.
