Lotzzz....
On any major repair I recommend that you get 3 or 4 estimates from local service facilities unless you are lucky enough to have a shop with an absolutely stellar reputation available. Compare the estimates and choose one of the middle estimates. My reasoning for this is the low estimate either left something out or worse is deliberately giving a low ball estimate to get you in and then when your car is all torn apart they find all sorts of critically important things wrong with it which run your bill through the roof. Do the leg work and be an informed car owner. No reliable technician or shop will give an estimate for repair site unseen except as a budgetary estimate which will be a range from the middle average to the unusual high end possible.
i was wondering how much it would be to rebuild a 1991 caprice engine....its a 305....just kinda of need a ballpark price...im in seattle also if anyone knows any shops
You would be far ahead getting a crate motor i'm sure a 305 would be cheaper than a rebuild and you have a warranty. In Virginia a rebuild would run you about 12 to 1500
