it is a 69-79 year block idk the exact year, i just ran the csting #. it is 4 bolt main. the crank is steel and balanced. It has keith black high performance pistons.
It depends on what rod's you are using. With what you describe above. If high nickel block, then the rods will be the weakest link. Stock rods vs good I-Beam rods will cause max boost to vary.
