Guest
·Go into the vehicle settings with the radio controls. With the key turned to ACC, hold DISP on the radio for about 6 seconds and it should go into settings mode. Press DISP until you see oil life in all caps, then use Prev. & Next to scroll to reset oil life mon., then push DISP again. you should here a beep and the display should read Done. Scroll to Exit and press DISP again.
