Horn Beeps Three Times
5375 Views 2 Replies 2 Participants Last post by  occupa
2013 Impala 3.6 regular gas 131K.
When I turn off the car and remove the key, sometimes the horn will beep three times.
Recently now it will beep three times and the the alarm will start.
Locking, unlocking not much seems to resolve.
Any thoughts?
Any thoughts?
When the alarm "starts" , what is it doing? More horn beeping?
Your issue reminds me of the SECURITY problem on the next earlier generation of Impalas. There is a sensor in the ignition cylinder that detects the presence of the key. The connection to the BCM was known to be iffy resulting in the BCM not allowing the car to be started because it could not detect the key in the cylinder.
In your case, you remove the key, and you get 3 beeps. Make sure you are turning the cylinder all the way to off. On cars with some age, the cylinders will sometimes allow the key to be pulled out without the cylinder turned fully counter-clockwise. So that would leave the ignition switch not fully off, but no key in the cylinder. I'm wondering if that could cause a security issue on this model.
The car always starts, right? The only issues are the 3 beeps and the alarm, but the car otherwise starts and runs?
Doug;
Thanks for the response, yes starts and runs fine.
The problem was the fob.
I changed the battery and that did not solve the problem.
I opened it up again and lifted the circuit board out.
On the back of the PC board where the grid work is for the contacts if found black residue or dust on all the contact pads.
Wiped off with tissue/cloth and have not had any problems since.
See less See more
Reactions: 4
