Hello,
Where is the high side AC connection located on my 2014 Impala Limited? Found the low side near the firewall.
Thanks!!
Thanks for the link. Looks like the High Pressure connector may be #7 but it's called Lower Press Hose Valve. If that's it, it may be under the air cleaner or other things in that area. Seems strange you'd have to take off the aircleaner just to connect to the AC high side to check the pressure.
