If you are unhappy with the HIDs might I suggest fresh bulbs, they do lose effectiveness over time and use. Changing bulb types can negatively affect light distribution.
Exception being the lower option cars that came with Halogens in an HID capsule, then the HID conversion helps light pattern a lot.
Discussion Starter #4
Exception being the lower option cars that came with Halogens in an HID capsule, then the HID conversion helps light pattern a lot. So would you recommend just getting a more power HID ballast instead? I think the factory come with 35watts if I'm not mistaken.
