1 - 20 of 30 Posts
Hey i Am getting mixed messages.with acold air intake And a reprogramed pcm is a safe to drop my pully size to 3.4 on my 04 impala ss
OEM LOL
your gonna get a huge amount of kr with that small of a pulley you probaly will lose power.
What is your pcm programmed too 91 or 93 octane fuel?
Get a
ubend delete
colder plugs
colder thermostat
then consider a smaller pulley
i know that a spacer will not increase your power as far as a whistle i couldn't tell you. Im not into random whistles in my car.
Also don't be surprised if the weak transmission blows with the pulley drop. so be ready to drop some cash on a built trans
I was told that the pcm would take care of the air fuel mix and it would also increase preasure to the trans I also bought a shift kit
OEM LOL
Do you want help or not dude.
If you are so sure of this tech then why are you even asking us.
Like i said if you wanna run a smaller pulley SAFELY
colder plugs
colder tstat
ubend delete
and at least a 91 octane tune
sure you can put that pulley on there and run it but with all the KR your gonna get you will lose power and kill your motor
also save up some money for a trans. These transmissions are very weak and upping the power will only decrease its life.
Discussion Starter · #8 ·
I am under the impression that different techs are veiwing in different areas its like I said in the other thread I came to this site six months ago and was told by many that I could go down to 3.4 safely with a stock motor
OEM LOL
Discussion Starter · #10 ·
What is unbend delete Android tstat I do have colder plugs Android a IAT wire extention so I can run it over to the fender away from the exaust for a colder reading also it has the hd trans in it you don't think it will hold up
Discussion Starter · #11 ·
Thanks I also did get a colder tstate and I payed extra to have the cat code deleted if that's what you mean Android its gonna take me anouther month but on he same site I found a complete exsuast headers and back
OEM LOL
No problem man make sure you have at least a 91 octane tune also
Tuning the air to fuel ratio or not you need to run high octane fuel with a smaller pulley
OEM LOL
Then grab
1 maybe 2 range colder plugs
180 degree tstat
ubend delete at least (headers and catback will also help greatly and is safer)
and then drop your pulley
Discussion Starter · #17 ·
I planned on doing a comlete exaust in about a month.if install two high flow mufflers and put a strait pipe inplace of thecat do you think that I will be fine for now I have the tstat andwill grab the plugs. I HAVE received the pullys but the rest is still comeing Ups hoopefuly Monday.
OEM LOL
The ubend delete isnt expensive and your gonna get a ton of kr without deleting it.
Its up to you but id delete the ubend before i dropped the pulley
Discussion Starter · #19 ·
I will. What I Android saying is that it looks like from that pic you sent that replaceing the cat with a strait pipe will delete the ubend andthe pcm was programed with arear o2 embalater. Are you sayin you don't think this will work.also what is KR?
OEM LOL
Engine knock, also known as "ping", spark knock, or detonation, is a phenomenon that occurs inside the combustion chambers when a portion of the air/fuel mix is ignited under extreme heat and pressure, burning more rapidly than it should for creating optimum power on the piston's downstroke. The result is a harsh detonation as the air/fuel mix explodes, colliding violently with parts of the engine such as the head, piston, cylinder walls, etc., as well as the original portion of the air/fuel mix that was ignited by the spark plug.
Knock can occur at different intensities depending on conditions inside the combustion chambers. It can be caused by various things, including low octane fuel, lean air/fuel mixture, higher boost (smaller SC pulleys), increased engine load, and restricted engine air flow, and all of these things may act to influence each other. Perhaps the two greatest direct causes of knock are: A) excess heat and B) a lean air/fuel condition. Warmer outside air temperatures, "hot" air intake designs, higher engine/transmission temps, incorrect spark plugs, and simply racing the engine at high RPMs can also contribute to heat build-up and knock.
KR stands for knock retard. Knock retard is the PCM's response to detected knock, which results in retarding of ignition timing. KR can be measured using an OBDII scan device. KR is measured in degrees depending on its level of intensity. The more knock that is detected, the greater the response by the PCM in dealing with it. As timing is pulled, power output is reduced. For obvious reasons, zero degrees KR is optimal, but this is not always realistic due to the nature of the engine's operation. Because our cars are supercharged, the effective compression inside the cylinders is much higher than with normally aspirated engines under increased throttle, thus we are prone to knock much more than NA engines when under loads. In fact, it is normal for a SC 3800 V6 to be on the verge of knocking during WOT (wide open throttle), or under heavy load conditions, such as pulling up a grade in overdrive. In order to take advantage of the extra air from forced induction (supercharging), knock is a sort of necessary evil, but you don't want very much. Ideally, you want to get the most power possible before engine knock ensues.
Even a stock vehicle can exhibit knock during WOT at times. If your engine is knocking slightly, say 1-3 degrees, you probably won't notice it, because the PCM uses microphones to listen for these sounds and then takes quick action to correct with KR. A small amount of power will be lost, but it is very small, probably in the area of 5 hp. Higher levels of KR above 4 or 5 deg may require extra response from the PCM to control the knock. When this happens, the engine could lose a noticeable amount of power, and a "ping" sound may actually be audible is extreme cases. When you use premium fuel, cooler plugs, a colder thermostat, or a cold air intake (CAI), you may notice restoration of lost power due to the reduction of existing engine knock (the only way to verify is to monitor KR using a scan tool).
Modifying the engine to run at higher levels of boost (swapping to smaller SC pulleys) can yield considerably more power output, but requires added effort to keep knock and KR under control. Running extra boost will increase heat and test the PCM's ability to deliver the needed fuel. Further lowering intake temps (IC), maximizing engine air flow (rockers, cam, exhaust), and tuning the PCM's fuel curves (PowrTuner) are just a few ways to help keep knock levels in check.
1 - 20 of 30 Posts
