I think that's because there is no such code, did you perhaps mean P0420?
Were would i diagnostics procedures for this code ? i tried searching the web, but no luck.
It can mean these things
Leaded fuel was used where unleaded was called for
A damaged or failed oxygen sensor (HO2S) Downstream oxygen sensor (HO2S) wiring damaged or connected improperly
The engine coolant temperature sensor is not working properly
Damaged or leaking exhaust manifold / catalytic converter / muffler / exhaust pipe
Retarded spark timing
The oxygen sensors in front and behind the converter are reporting too similar of readings
Leaking fuel injector or high fuel pressure Cylinder misfire Oil contamination
