I HAVE A 95 IMPALA SS . I CHANGED MY WIRES AND PLUGS. FLUSHED THE COOLANT AND CHANGED THE THERMOSTAT..
PROBLEM: MY CAR JUST SEEMS TO JUST STOP WHEN IM DRIVING AND WHEN I COME TO A STOP.ALSO MY CAR STARTS TO OVERHEAT WHEN IM IN PARK AND WHEN IM DRIVING THE CAR IS FINE.MY FANS COME ON .I ALSO HAVE A EXHAUST MANIFOLD LEAK
WHAT CAN BE THE PROBLEM?:frown:
It Also Takes Awhile To Accelerate
The overheating is due to air in the system. Bleed it and that should work.
As far as no power, did it run fine before you changed the plugs and wires? If so, check the wires to make sure they are going to the correct cylinder. If you have headers, spray a little water on the tubes to see which ones is affected. The tubes that don't evaporate the water as fast are the cylinders that could have issues.
