Cooland doesen't bleed out of coolant bleeder screw.
I wanted to check my coolant system for air to be safe but when I open the bleeder, I can see fluid go by but its not bleeding out.
My question is, why do you think it wouldn't bleed out of the screw with the heat turned on and engine running.
I have not detected leaks, how ever I think it could be due to a water pump going out?
