have a 2003 impala, the internal alarm made it to where i can not start my car, everything else works fine, radio, windows, etc... went to the car dealership and they informed me it wouild be 750 to reset the system well i do not have 750 for anything at the moment, ive heard all kinds of ways to reset it , from opening and closing doors, to un hooking the batteri for 10 min etc... some how the car is unable to get gas when i try to start it, there must be a relay swithch i can reset or something, i have a friend who is very good with cars, i just need to know what to tell him to do and hell do it, so anyone have any ideas or even a decent priced place i can go to get this reset, thanks have a good one
you'll have to turn your key on without starting the car, and leave it on for about 30 mins.
However, impala's are known for having back passlock sensors in the ignition lock cyl, that might be why your bill would be $750 (even though I think that's too high)
2002 Chevy impala
I have a 2002 Chevy impala I had to put a new starter. In and a new battery my car turns over but won't start ..........My security light is on i need to reset it I tried. The technique of having my car in the on position for 10 miss den off for 20 sec den on for 30 minutes but off for 2 sec neither work what can I do
[QUOTE = "jerrisha1, publicación: 1095602, miembro: 52018"]
2002 Chevy impala
Tengo un Chevy impala 2002 y tuve que ponerle un motor de arranque nuevo. Mi coche se da vuelta y no enciende una batería nueva .......... Mi luz de seguridad está encendida. Necesito restablecerla. Lo intenté. La técnica de tener mi auto en la posición de encendido por 10 faltas de guardado por 20 segundos por 30 minutos pero apagado por 2 segundos tampoco funciona, ¿qué puedo hacer?
[/CITA]
Se que este archivo es viejo y veo que nadie da respuestas ... pero esta información puede servir a quienes en este 2021 tienen todavía este problema y buscan alguna respuesta !!!
Para resolver hay varios escenarios y se requiere mas información del auto con el problema ... Para auto chevrolet 3.8 con llave sin Chip, lo recomendado es SOLO cambiar el cilindro del Switch + su llave .. luego reprogramar por el método de los 30 Min fraccionado 10 min x 3 sesiones.
Para autos con chip las opciones van de lo costoso a lo super barato.
Costoso. Medir la resistencia del chip, esto se hace con multimetro. Comprar cilindro + la llave y mandarla a programar.
Super Barato .. Medir la resistencia del Chip. Comprar resistencia cerámica con mismo valor Ohmios.. cortar cable amarillo que llega desde BCM hacia la ignición, cortar cable ***** que va a la ignición, tanto la punta del amarillo como el ***** que quedan sueltos en la ignición ignorarlos y cubrir sus puntas con cinta aislante para no interferir. entre el amarillo (Voltaje 5 Volt.) que viene de la BCM, y ***** (-) que viene de BCM, unirlos por medio de la resistencia con el mismo valor del Chip... Realizar el procedimiento de los 10 MinX 3 sesiones y debe Encender Motor... yo ejecute con éxito en Impala LS 2004 Motor 3.8 llave sin Chip.
