Help!!! 95 Impala Doesnt Start (pass key fault)
1 reading
6.7K views 3 replies 3 participants last post by  ahrodriguez13
#1 ·
Hello Guys,
Well i need help! yesterday i was to the store i sow a light Show up (LOW) i had no idea what it was, i stop and check the oil and it was okay! few seconds latter it dissapear! and everything was okay!:frown:
when i was on the store already i turn the car on! everything seems fine and i sow a light (pass key fault) i was like mmmm what is this!!! everything was okay i was driving and on my way home and the car running on 60 KPH on the freeway and then the car TURN OFF BY ITSELF NO IDEA WHY!
i try to start it! engine cranks but refuses to start so i had not idea what is it! i put the key on start positions and the pass key fault icon shows for few seconds then dissapear and then the check engine light stay on!
I already Clean the Key,Check Fuse and Relays,and i Reconect the Battery! any other????
any suguetiongs?
i will appreciate any suggestion! thank you all:eusa_wall:
#4 ·
I had the pass key light come on for me one time. I could not start my car. I just waited for a couple hours and tried again and it worked. I know that the pass key means something to do with that little chip on the key. Maybe the problem is in the ignition if you cleaned the key and it still doesn't work. Good luck bro.
