Do you still remember which connection was loose on your car? Did you check all the connections from battery to the starter? My battery is actually old, I replaced it in 12/2016, so it's indeed time to change. This problem first occurred in a very cold freezing day, and the battery voltage reading was about 11.5 V at that time, and since then I haven't got it started up again. I will check the connections and try a jump start then, thanks a lot for your information !Classic battery issue. Doesn't matter if the lights are bright and everything looks fine. I've been through this exact same situation ... last year, actually. Double-check your connections. Make sure they're super clean and tight. My connections looked super clean, but one of them wasn't tight ... even though I hadn't touched them in forever. Just vibrated loose, I guess. You could put a little pressure on the terminal head and spin it a bit. Didn't even suspect this because the first thing I checked were the lights. Was embarrassed when it turned out to just be a loose connection!
A 2006 probably needed a new battery in 2010-2011, then again in 2015, then again in 2019-2020, and the current battery is what ... two years old? If your connections are clean and tight, then get the battery load tested. Might have a dead cell inside ... and maybe you get some pro-rated amount toward a replacement battery ...
It was the POS (+) cable that was loose. And No, I didn't check the connections beyond the top of the battery. It was my fault entirely. Just didn't tighten it enough. It worked fine for a long time, but then one day ... click ... click ... click (leaving work one night). Lights were bright as day! One of the co-worker guys came out to give me a hand and when he saw the lights were bright as day he pushed on the battery connections. 30 years working on my vehicles and I didn't even think to do that. Embarrassing!Do you still remember which connection was loose on your car? Did you check all the connections from battery to the starter? My battery is actually old, I replaced it in 12/2016, so it's indeed time to change. This problem first occurred in a very cold freezing day, and the battery voltage reading was about 11.5 V at that time, and since then I haven't got it started up again. I will check the connections and try a jump start then, thanks a lot for your information !
Be careful relying on a Viking.It was the POS (+) cable that was loose. And No, I didn't check the connections beyond the top of the battery. It was my fault entirely. Just didn't tighten it enough. It worked fine for a long time, but then one day ... click ... click ... click (leaving work one night). Lights were bright as day! One of the co-worker guys came out to give me a hand and when he saw the lights were bright as day he pushed on the battery connections. 30 years working on my vehicles and I didn't even think to do that. Embarrassing!
Buy yourself one of those small "jump start" Lithium battery packs. Harbor Freight sells a "Viking" unit for around $80 ... that's what I bought. I've used it a few times. Seems to work well. It'll get you started anywhere when your battery fails (instead of waiting forever for AAA). Just need to charge it about once a month in the house to make sure it's got the strength to do the job. Comes with a carrying case and fits in the glovebox (or trunk).
I had the same problem recently turned out the commutator bars where the motor brushes deliver their current were burnt in spots and if landing on those spots the starter will not turn the motor over to start the engine.Repeated one single click sound when turn key to ignition. Dashboard and all lights are working fine. Checked battery, starter relay, ignition fuse and a few other fuses, all fine. Please see the symptom in the video:
