Hi everyone-I have a 1964 Chevy Impala and the headlights all work on high beam but when I depress the dimmer switch all of the headlights go off and none of them work. Have replaced the headlights and the dimmer switch and the problem persists. Do I need to replace the headlight switch or perhaps search for a wiring problem? Any suggestions??
Sounds like a wiring problem
Hard to say - sounds like some old-fashioned checking with a multi-meter needs to happen. Sounds almost like power is not getting through dimmer switch. or maybe you have wrong dimmer switch for car? Possibly a negative ground is not being made for regular headlight aspect of circuits?
