33 coupe
Open the Hood,and locate the screw from the headlamp assembly,remove it.pull the plastic headlight retainer(white)out.Then pull the headlight assembly out away from the car.Remove the round dust caps so you can get the bulb out.Turn the bulb counterclockwise to get it out of the assembly.Take the electric connector out of the bulb by raising the locking tab and pulling the connector away from the bulbs base.Reverse the procedure to install.Good Luck
