You know you should really understand what the parts are before you go looking to swap them. My understanding is your car should have 243 casting heads his car probably 241, YOUR HEADS ARE MUCH BETTER. Hell yours are the most desirable of the cathedral port heads, same casting as used on the LS6. The 243s you should have are so much better guys with Camaros will swap them on unported, usually quoted for about a 15hp gain.
Edit:
The 2002 LS1 seems to have gotten the LS6 intake which is better.
If you wanted to make 15 less HP to keep the tranny alive then the head swap seems like a good idea.
Don't go blindly assuming f-body stuff is better especially when it is so much older. OEMs constantly learn to do things better or find a little more power, or in some cases sure they make something cheaper and hurt power but not nearly as often as they improve.
On the intakes the early LS1 intake is down like 9hp 11tq from a truck intake, but the f-body owners will tell you a truck intake couldn't possibly be good. Now you can not consider a truck intake but the point is "LS1" doesn't make it magical.
GM's 6.0L LS Series Small-Block - Tech - Tune-up - Hot Rod Magazine
