Working on installing a A129 Dashcam. I'm working inside the fuze box under the glove box and I'm connected to the 25V RAP for ACC power using an "add a fuse" kit but I'm having trouble getting Constant 12V power with the 2nd "add a fuse" kit..
I tried plugging into the door lock fuze, and not sure why I'm not having any luck what suggestions do you guys have?
Here's the hardwire kit.
https://www.amazon.com/dp/B07KZGM9LS?psc=1&ref=ppx_yo2_dt_b_product_details
Anything that sounds off?
Water Hand Drinkware Bottle Liquid
The fuse tap may be intermittent, have you verified the power using a voltmeter or better yet a 12v lightbulb? Not all digital meters are fast enough to show a glitch and the lightbulb will simulate the loading should the connections be intermittent or corroded. I've had problems with the slip on fuse taps and prefer to pull the fuse panel and solder directly to the terminal cavities.
