The rubber boot on the driver side half shaft is coated with grease. Looks heavier than trans fluid. What could it be from?
It's probably a pin hole in the boot if the shaft is still good I'm pretty sure you can buy a new boot then just fill it with half shaft grease
Inside the boot, they are filled with grease. When the boot cracks or breaks, the grease comes out, and the joint wears out. You may be able to just get the boot replaced at this point and be ok.
