What source and type of replacement socket/ harness are others using?
I have a low beam headlight that has been acting up and not working. Started some time back and the original socket was all brown (white molded plastic) from the heat and corroded also at the contacts. I ended up going to the part store and asked about replacement. They recommended 2 different ones.The one was according to them a basic, and the second a bit more money but designed for higher temperatures. Not 100% sure of the brand but all my searching show this similar style. I purchased and installed the better of the 2 that had the higher temperature rating and it was pretty hard to get the plug on the bulb because it was a longer mount harness. Had to put the bulb in the lens and then get the plug onto the socket after it was in place due to the tight fit. But I did manage to get it working and the wires were tight against the edge but solved the issue of the light cutting in and out for maybe 6 months. Then it was again intermittent. Now it is pretty much failing all the time. Today I took the lamp assembly out, checked everything out and verified the bulb is not burnt out. I removed the bulb from the mount, put it back on and tested and if I wiggled the wiring in the back I could get it to light up. I tried to zip tie the wires and wrap it with some tape and again as soon as I put the bulb back in it was loosing contact and not working.
Not the exact one- but the harness is very much like this:
Any source for a shorter socket, or am I doing something wrong in the mounting of the bulb/socket?
