Anyone know of a good mechanic in tampa to work on my 95 9C1 caprice? Car has been sittin for 3 years. Put a new fuel pump, Mass air flow sensor, egr and egr solenoid, throtle position sensor. Does not start up right away. Have to turn it over a couple times before it fires up. Once it starts it like sputters almost as if its goin to stall. After it warms up it revs fine nice and strong. No smoking or knocking sounds strong. Put it in gear and rpms seem normal at times other times idles low. But once you drive it it feels like it has hardly no power. When the trans is suppose to shift it takes longer than it should. But does shift! I have read all kinds of forums online and replaced the above mentioned parts. I just dont want to take it to any mechanic due to my distrust of the majority of them. I would preffer a person that comes reccomended by actual customers here in tampa. Any all help/info would be appreciated. Have had my 9C1 5 years now and would love to get it running right.
Carlos
Things to check:
Idle Air Control
Fuel Pressure Regulator
Opti Spark Distributer
Vacuum Leaks
O2 Sensor
Catalytic Converter
Hope this helps.
