As you can see in the picture below I have no gas pedal to speak of.
I have the part that goes thru the fire wall but no actual pedal.
I do have the 2 studs in the floor.
My question is:
I found a pedal in ecklers for 18.99 but from the pictures it looks like I need another part to make it work, there is no place in the back for the ball coming off my pedal rod.
Here is the link:
http://www.lategreatchevy.com/product.asp?pf%5Fid=529023&dept%5Fid=1282#
I also found a part number for the bushings
Here is the link:
http://www.lategreatchevy.com/product.asp?pf%5Fid=563420&dept%5Fid=1268
Am I missing something else or will these two parts make it work correctly??
Thanks in advance for your time and responses
Later
Bernie
It looks fine to me. I think that pedal is supposed på be mounted on the floor, so that it leans against the tap, you allready have going true your firewall. Correct me if i´m wrong!
The pedal is a floor mount, and the rod that's coming through your firewall just slides down the back of the pedal when it is depressed. If you need pics of what it should look like stock lemme know and I'll run down and snap a pic of mine.
Thanks for the info guys
Check it out
Isnt it funny how when you first start a project the smallest things get you all excited. I mean its only a gas pedal and Im pumped!
Cant wait till I start on the body work and see some real improvment, Im going to be off the freakin walls
LOL
I also did the parking brake release handle mine was broke.
Now I need to get a new vent knob, that just looks bad, one new one missing.
Thanks again
Later
Bernie
