1 - 10 of 10 Posts
Does anyone know where the fuel rail service port is? I wanted to check fuel pressure at the fuel rail, but the fuel line appears to run under the intake manifold. I didn't see a schrader port anywhere on the fuel line. Any info is appreciated.
Year, make, model, and engine would be helpful.
8th generation Impalas used several different engines.
There isn't one. Both high and low pressure can be checked via a scan tool.
Be careful. The fuel rail is the high-pressure side of the system. The pressure must be bled off prior to servicing.
Discussion Starter #6
Looks like a scan tool upgrade is next. Any suggestions for an affordable model that will read live data?
How affordable? The ELM 327 with the TORQUE app on your Android phone will read live data. If I get a few minutes tomorrow I'll see if it's picking up both fuel pressures.
1 - 10 of 10 Posts
