1 - 9 of 9 Posts
I have an '02 Impala, and the front bulbs needed replaced. Worked fine, simply no amber paint left on the bulbs. So, I went to eBay, bought a pair of these (LINK) and put them in.
Problem is, I can see inside that there are 2 sets of filaments, but only the small one is lit, so, the bulb is kinda dull compared to the old ones. I rotated the bulb 180' and tried it again but still just the smaller filament being lit.
Did I get the wrong bulb? shouldn't, if only 1 filament being used, the larger one be lit instead?
3157 Amber Color Chrome Light Bulbs Park Signal 3057
CROSS REFERENCE
3157 =
3057 3157 3357 3457 4157 (dual filament)
12V-27W
COLOR
Super Amber
FEATURES
Dye infused glass with chrome - will not fade
QUANTITIES
2 pcs Bulbs
It should be a 3457A bulb the A is front.
Low Beam Headlight Bulb Size: 9006 or 9006 HID Upgrade Kit
High Beam Headlamp Light Bulb Size: 9005 or 9005 HID Upgrade Kit
Parking Light Bulb Size: 3457ALL
Front Turn Signal Light Bulb Size: 3457ALL
Rear Turn Signal Light Bulb Size: 3057
Tail Light Bulb Size: 3057
Stop Light Bulb Size: 3057
High Mount Stop Light Bulb Size: Assembly
Fog/Driving Light Bulb Size: 896
License Plate Light Bulb Size: 194
Back Up Light Bulb Size: 921
Front Side Marker Light Bulb Size: 194
Rear Sidemarker Light Bulb Size: 194
Ash Tray Light Bulb Size: 194
Glove Box Light Bulb Size: 194
Map Light Bulb Size: 194
Dome Light Bulb Size: 578
Step/Courtesy Light Bulb Size: 194
Trunk/Cargo Area Light Bulb Size: 912
Ya but, the bulb says "3157 = 3057 3157 3357 3457 4157 (dual filament)"
When does the 2nd filament come into play?
When the turn signal is on or the hazzard lights.
I would say the chrome coating is why it isn't bright.
I tried with both and from what I can tell, just the small filament for both... I'm simply confused as to what that 2nd filament is for. :S
Chrome isn't very heavy a coating... barely there at all on the sides. Maybe just crappy eBay quality.
I would say its due to low quality ebay bulbs along with a not so great coating to them. 1 filament should be lit when just the park lights are on and the 2nd filament only gets power when the signal is on sending power to the 2nd filament.
Discussion Starter · #8 ·
Ha! I have that bookmarked. :D
Was confused because Amazon's description said it has a bright white light, but comments all said amber.
Though I have to wonder, is it amber glass? The old ones I had were Sylvania and still work great, but no amber paint left.
1 for running light (or parking light)
one for turn signal.
1 - 9 of 9 Posts
