I think the window track is attached along the bottom of the window with rivets but usually you leave the old one on if you get a junkyard replacement so I've never messed with them.
If you mean the big headed rivets for the regulator and door pull I used Ace 201445 which are 3/16" diameter with a 1/4 to 3/8" gripping range. Window motors are held in by rivets but the replacements come with nuts and bolts to reinstall them.
Good luck!
