Status
Not open for further replies.
21 - 40 of 622 Posts
Harley fanatic
I see you are from Kokomo, I am just north of you.
Blacked out the trim around the windows with plasti dip
You are talking about the rubber trim correct? Did you use plasti-dip from a spray can? You take the trim off or just tape it up good? What kind of prep did you do? This seems like a really good solution to mine which, are faded badly.
aka IMPALER
Discussion Starter #26
I plasti-dipped the chromed plastic trim around the windows. Prep with plasti dip is VERY easy. Not much you need to do. I prepped around the outside and covered any cracks. Basically planned for anykind of overspray you might have. If you cover the other areas with the 3-4 coats like the trim, you can just cut your lines with a knife and peel it off. I'll post up a video of what I mean when i can.
^^ Sweet thanks for the info! I think if its warm enough this weekend I am going to do mine. I will probably do a coat of gloss black and a clear over it though.
that'll look good, i'm planning on having mine professionally done once I've got the money
Sent from my SGH-T989 using AutoGuide.Com Free App
Nobody works on my car but me! Except for special circumstances like tire changing, welding, or things I dont want to deal with (spark plugs).
aka IMPALER
Discussion Starter #31
trust me if i knew how to paint I'd be right in there doing it myself.
UPDATE: should be getting new tires within a week or two. looking at either fitting 285's or 275's. Obviously the wider the better but there seems to be a discrepancy regarding the contact patch with a 285 wide wheel on an 8.5" rim.
aka IMPALER
Discussion Starter #32
Got new tires mounted yesterday, Nitto NT555 Extreme ZR. I went with a wider size on all four corners at 275/40r17. Rides like it's on rails, day and night difference from the balding Kuhmo tires.
Any rub at full lock?
How on earth does that work? I mean, great, but how?
aka IMPALER
Discussion Starter #36
something about the tire aspect ratio compared with the front suspension. I don't honestly understand it myself but hey i'm not complaining! :eek:k3:
here's some recent shots of it I took today..
http://flic.kr/p/dpzy2Q
Also did some tire & suspension "testing" today. It was just all in fun but the reality is the tires are glued to the road. And despite how slow it looks, i'm actually pushing it quite hard through the circle.... or as hard as i could with a big gulp in a puny cup holder :lol:
The F*** Killer
I like your horn at 0:15 sec. through the video LOL. Looks much SICKER with the smaller side wall, makes the SS wheels look bigger.
Status
