Flusing Brake fluid
5399 Views 5 Replies 4 Participants Last post by  John Craker
Just as the title states. Flushing the brake fluid.
I flushed the brakes for the 6th time on my Impala and the first time on my 2005 Silverado this weekend. I've tried to stay on a schedule of every 24 months or so since she was built on August 1st 2008 with the Impala. The first change was the swap over ATE SL.6 DOT4 in December of 2009.
My guess is the Pickup has the same Brake fluid the GM line workers installed in September of 2004.
Why? Two reasons and either one is a good reason to change the stuff on a regular basis. Both together is double that.
  1. Brake fluid attracts moisture from the air... 3% H20 will reduce the boiling point of your brake fluid by 100°F.
  2. Brake fluid has an anti-corrosion add pack as well that gets depleted over time. Brake lines over the last two decades were Ni-Copp or copper brazed steel tube. When the corrosion inhibitors break down the oxidized copper from the corroding brake lines can screw up the ABS motors.
The black crud granules in the bottom of the catch bottles I used to catch the flushed fluid on my recently acquired 2005 Silverado and the lack of the same from my 2009 Impala tells me I must be doing something right.
I NEVER bleed by pushing the pedal on a used master cylinder. The cup seals can get damaged by moving past the wear ridge in the bore into an area not traveled in normal operation. This can screw up the seal cups. Not always but why tempt fate.
I bleed with a pressure pot. This is Eric O in Central New York State using a Brannick... Real nice simple easy to use tool but there's no way I'm spending $350 on one of those for my occasional use.
I prefer hoses and catch bottles on the bleeders but his method works.
I built a weed sprayer pressure pot for under $20 when the parts were cheaper and the Motive pot was priced over $75;
You can find build instructions if you google it.
You can get the Motive pressure pot from Summit now for less than the price of the parts to build a sprayer base now. It has a gauge, pressure relief valve, and non-aerating pump for $35. Why bother building your own at that price?
https://www.summitracing.com/parts/...yYXHmXIPh0Anev5ocCUCtO0EVztXLhN8aAtWXEALw_wcB
Pressure Bleeder Master Cylinder Caps:
The Motive 1108 Nylon & 1118 Metal pressure caps seal to the top of the Master Cylinder neck. I have the 1118 cap and it leaks. I don't see how the 1108 wouldn't.
Auto part Handle
Technology Cable Fashion accessory Electronic device Circle
I have an SPX J-35589 that has an o-ring seal inside the filler neck. The J tool is metal however injection molded reinforced nylon would likely work quite well as long as it had the provision for the O-ring seal inside the MC neck.
Stock SPX photo of bottom. You can see the O-ring seal that makes this cap much better.
Product Auto part Brass Metal Wheel
My own well loved 35589 cap.
Auto part Wheel Household hardware Washer Hardware accessory
Tin
You can find em on Evilbay for around $30-$40. Be mindful of the Shysters that are selling the elbow.
https://www.ebay.com/sch/i.html?_fr....TR11.TRC2.A0.H0.XJ.TRS1&_nkw=J35589&_sacat=0
If you have a small lathe you could probably machine a slug to fit the MC neck with an o-ring groove to seal it. Drill and thread the centre 1/4NPT and keep it from blowing out by drilling a hole in a sacrificial GM Master Cylinder cap for the hose barb to poke through. Not as neat as the GM tool but pretty close and I bet it wouldn't leak.
The Brannick plug cap in Erics' video is a neat idea as well but I don't have one of those and I bet they ain't cheap.
With that in mind here is the rest of the list to fit the tool to your rig.
  • SPX Kent Moore J-35589 master cylinder cap
  • 1/4" NPT hose barb for the SPX cap
  • 1/4" Clear fish tank hose extension for the master cylinder cap (if you decide you need a longer hose)
  • Clear fish tank hose to fit the bleeders
  • four catch bottles. (1L or 2L soda bottles with two holes in the caps will work... one hole for the bleeder hose and one to vent)
Flush the old stuff out with the new stuff.
I usually suck out the Master with a turkey baster or big fluid swap syringe. Make sure the fluid suckers have been cleaned with Isopropyl alcohol and they're completely dry before you stick em in the Master Cylinder.
Then I re-fill the master with fresh fluid and hook up the pressure pot.
The GM service manual says 25PSI but I usually only run 20PSI.
Use a SIX POINT socket or box wrench on the bleeders.
I start opening the bleeders at the end of the longest run at the LR corner then the RR then the RF then the shortest line at the LF corner. You can go the other direction from short to long as well. Your choice. I like long to short. Just have a plan and stick to it. If your fluid is as dark as most folks you won't have any difficulty seeing the change from crap to fresh fluid.
The pedal feel and height is not good if you don't exercise the ABS motors. You have to run an ABS "Bleed" with a diagnostic tool after each bleed cycle to get your pedal feel and height back.
If the old fluid is exceptionally nasty, like my pickup truck was, I'd flush it a second time after exercising the ABS motors. You should exercise the ABS motors after each bleed/flush cycle to re-set the pedal height and feel again.
I changed my fluid to DOT4 when I did my first flush. Cue the guys telling me the world will now end...:lol::lol::lol:
I like to keep the boiling point of the brake fluid as high as possible.
I chose the DOT4 fluids that I use for that reason. Yes some DOT3 fluids have higher than minimum spec. They are not what I choose to use.
Minimum specs on Glycol based DOT brake fluids.
  • DOT3 dry boiling point is 401°F. Wet is 284°F.
  • DOT4 dry boiling point is 446°F. Wet is 311°F.
DOT4 is downward compatible with DOT3 systems but it's inadvisable to use DOT3 in DOT4 systems.
DO NOT USE DOT5 or DOT5.1 in DOT3 or DOT4 braking systems. DOT5.1 is glycol based but supposedly it's not backward compatible. Not easy to find either.
ATE and Pentosin brake fluid comes in metal cans. It may not be a big deal but the brake fluid in metal cans always tests to 0% H20 contamination and that gives me warm fuzzies.:lol:
I run Pentosin LV DOT4 or ATE SL.6 DOT4 in my vehicles. It has boiling points much higher than the bare minimums. Actually closer to DOT5.1 boiling point specs without being difficult to find. Both are compatible with the bits in my brake system that were designed for DOT3.
The SL.6 & LV variants have a lower viscosity index for the frozen North country too.:lol:
You can get a GM Master Cylinder cap that correctly reflects the system contents from a more recent GM vehicle.
April 16, 2019 GM price on the 92457850 DOT4 cap was $4.98 at my local Chevy dealer.
Bleeders:
Last and not least. Bleeders... Two things that will save a lot of grief the next time you have to service these.
  1. Remove the bleed screws completely and coat just the threads with NeverSieze. I like disposable plumbing acid brushes for this kinda stuff.
  2. Install or re-install the rubber bleeder caps or condoms or whatever you would like to call em. Keeping the water, salt, and general road crud out of the core will keep them from seizing in the calipers. They're worth the $2-$3 it costs to buy four.
The difference #2 makes.
With a cap... Nice clean tip and clean inside. No sign of corrosion where the cap was installed nor is there any inside the bleeder.
Auto part Vehicle brake Brake Disc brake
Without a cap. Dumb blind luck if this rusty lump threads out.
Organism Hermit crab Formation
In the 80's when I was young and poor I'd grab bleeder caps off the German cars in the salvage yards for my American Iron. I never saw them on US made rigs at the time. I'm not sure if they were used.
See less See more
8
Reactions: 2
Good stuff, hatzie. Thanks for putting that together.
Seems like, every time I do a brake job, I add another step. For cycling the ABS as part of bleeding, are there any alternatives to a diagnostic tool? For example, if I remove the connector at the ABS assembly, could I jumper +12V to a couple pins to power the motor? My fear is that I might damage something doing that. Or, more benignly, I might need to send a more complex voltage pattern rather than simple DC.
On my 1997 F150, I have lots of pedal travel on the first pump, then a good, firm pedal after that. (It has rear ABS drums.) I'm wondering if running the ABS during bleeding might help with that.
Unfortunately no alternative that I'm aware of. Not sure what the Ford ABS systems required back that far. I know the second design GMT400 trucks starting in 1995 or just before with the Kelsey Hayes ABS system have to be bled with the scan tool to get any kind of decent brake pedal feel. The older Bosch RWAL brakes on the 88-94ish trucks is better off bypassed.
I have a couple thousand dollars sunk into "obsolete" scan tools over the years. Shaking my head...
I have an Mastertech MTS3100 for 80-92ish GM stuff... it'll do more vehicles but it's a treasure hunt to find the cables and cartridges.
I have a Chinese Tech 2 for the 1993-2012ish stuff and a Chinese WiFi MDI with Hacked copies of Tech2Win and GDS for the more recent GM stuff... the MDI requires a laptop but it's darn nice to have a stable J2534 interface for programming GM controllers back to stock.
My Ross Tech Vag-Com HEX CAN cable and VCDS is good for most VWs up through 2011 or so... but I need a laptop to use it.
I have an old Snap On MT2500 Red Brick with various personality keys and cartridges for the 80's & early 90's Chryslers and Fords.
I have an out of date AutoEnginuity interface with the GM extensions for my 6.5L diesel in the software... again on my laptop. I use a Tech 2 on that truck when I can now.
I don't have a good read on good all around bi-directional tools that will speak Ford, GM, Chrysler, Toyota, Honda, etc well.
I've seen several from Autel and Launch but the tools in this class tend to start around $400 and even the $2,000 tools tend to cover some manufacturers better than others.
The lack of general information on the capabilities of these aftermarket tools is obnoxious. Probably because most people aren't really doing that much of their own work.
See less See more
Reactions: 1
The fellas over on the Taurus forum engage/exercise the abs on a gravel road a few times and come back home and do a 4-wheel bleed. Their claim is a much improved pedal?
Reactions: 1
Done that on a 2000 C2500 GMT400 chassis truck.
It works. Kinda...
Having done both... It's better than nothing at all but it's not as good as what you get by actuating the ABS motors with the proper tool. Probably because it doesn't fully exercise the motors for all four wheels.
Reactions: 1
No, you can't - and even if you just pulled the power lead off the ABS pump motor and powered it, it still wouldn't work. As the Tech-II runs the motor, it's also sequencing valves inside the ABS unit, directing fluid through its internal passages.
Reactions: 2
