l have been upside-down in the car under the dash and l'm not 100% sure of where l should be looking.. l THINK its in the FAR right (passengers) side up in there... ANYONE know for sure??
RIGHT SIDE OF DASH, MOUNTS ONTOP OF HVAC BOX
Removal
Notes
Body Control Module
REMOVE OR DISCONNECT
WARNING: Disable the Supplemental Inflatable Restraint (SIR) System. Refer to Air Bags (Supplemental Restraint Systems).
Right sound insulator.
Glove box module.
Nuts securing dual sensor pigtail wiring and resistor module to Body Control Module (BCM) studs and position aside.
Nuts securing Diagnostic and Energy Reserve Module (DERM) to DERM/BCM bracket and position DERM aside.
Bracket retaining clip from Instrument Panel (IP) wiring harness.
Nuts from BCM studs.
Screws from DERM/BCM bracket and bracket.
Electrical connector and BCM.
Pull out the glove box, and you will see the BCM and the computer. I had to replace mine last fall. I cannot remember what each look like, but you can look up the parts on Rockauto.com and will have pics.
