Welcome to the Forum. I am not sure if it is the same issue as it is hard to say really without seeing the car in front of you... Trying to understand better what it does...
Lets say you start the car, All does the testing and then all works for a sec or few. Then it shuts off all power to the cluster However you can still see the Miles, and the Warning area stays lit up if you have your door open? The Shift Selector (PRD321) disappears, There is some clicking sounds? then all comes back on may even show the low battery sign on the warning area?
If that is how it works I would try and clean up all the grounds in your car. Starting at the battery. Clean both power and ground.. Once that is done, Check all the grounds at the BCM. I think if it is working like stated above after cleaning the battery connections could help... If it isn't like that it could be a BCM issue however is another reason I was saying check the grounds there as well...
Let us know what you find!
James
