My '93 Roadmaster has a stock 5.7 Chev engine. At light loads (around 1500-2000 rpm), the car bucks as though there is an ignition miss. At lower or higher speeds, this is not noticeable.
Plugs, cap, rotor, and wires have about 20,000 miles on them. The only thing not set to factory spec is timing. Book says 6 degrees with the electronic advance disabled. I've set it to about 10 degrees in an attempt to improve highway mileage. Problem did not occur until about a year after setting timing as described.
Any ideas?
Any ideas?
