i just bought 04 impala but only with 1 set of keys does it require a key with a special chip in it or can i just go to like ace hardware and make an extra key
I dont think it has a chipped key. If the key you have that starts the car doesnt have the chip in it , a regular made key at ace hardware should work. I think GM did away with those type of security systems in the late 90`s.
If its anything like our 2003 , the security feature is in the lock area , and not in the key itself .
There is a piece stationary with the electronics on it , and the piece in the lock cylinder that turns with the key . Pull cylinder out and you can't start the car .
We have a regular key from a hardware store that works fine .
Your car such as my 02 has something called GM passlock II which reads resistance on the key when it is turned to the crank position. Using a key that has no resistance will not allow the car to start.
Take the tumblers out of the ignition , and any piece of metal will start the car . I know ............... damn lock cylinder failed one night , and I DO NOT call the tow truck :biggrin:
I have a similar issue. My 05 i bought a few weeks ago didnt come with the original key. Some sort of hardware store key without a resistor from what i can see. Car started and ran fine up until a few days ago. No it flat out won't start/crank. You start it from the starter and it kills itself after a second or 2. Definitely security system. Am having trouble locating the correct resistance for the original key. Been told by a few people to bypass the system using the correct ohm resistor but obviously i do not know the correct resistance. Any suggestions?
This has been bothering me for a while i am only getting 22mpg. I do go to a lot of stops, but a lot of times im also going a constant speed of 60. and i try to hyperdrive as well.
I have 20 inch rims on but dont think it should effect it that much
My air filter has already been replaced.
I...
I have a 2005 impala. When I got it the radio would be on max volume and sounded like I only had tweeters it wasn’t very loud at all. I replaced the factory radio with a aftermarket radio and it still sounds the same low volume. And I also bought new door speakers and still the same issue, help...
I am curious if my 2009 Impala LT has either Bluetooth capabilities (upf codes) and I am also interested to know if it has keyless start capabilities as well.
Thanks!!
