$1,600 in parts, yikes. Sounds like the only thing worth saving is the housing. Does sound a bit steep though... I replaced everything in the axle of my 96 Caprice 9C1 except the axle shafts, and it was about $700-$800 in parts.
You can get an 8.5" axle out of any 91-96 Sedan, and it will physically fit. The disc brake setup, can be swapped to any sedan 8.5" axle of the era.
They came in two widths. The Impala SS, and 93-96 Civi Caprice sedan used the wider housing. The rest, used a housing that was slightly more narrow, so the axle shafts are different. Roadmaster sedan, 91/92 Caprice Sedans, and 91-96 Caprice 9C1's.
Then you have the issue of different gear ratios. For 94-96, only the Impala SS / LT1 Caprice 9C1 used 3.08's. The L99 Caprice 9C1's used 3.23. Posi was optional on the 9C1's, standard on the SS. Roadmaster sedan / Caprice sedans the the towing package, used 2.93 Posi(standard). Roadmaster sedans without it used 2.56, posi optional.
Then when you go older(91-93), they used 3.08 on the Towing package / performance sedans(like the Roadmaster/ LTZ Caprice). Some of the 91-93 Caprice 9C1's used 3.42's. I pulled a 92 9C1's axle that was 3.42 posi. Replacing bearings/seals to put it in one of my Roadmasters, and swapping on the disc set up to it, more for looks than braking. The disc setup from the factory was crap. GM used the same proportioning valve for drum/disc rears, and that caused the disc brakes to SUCK out back.
So to sum things up, check the SPID sticker for the gear ratio code at the junkyard, and you might stumble on a 3.08 or better(3.23, 3.42) rear axle. i would not worry about the width difference, unless you HAVE to have the stock SS rim lip right at the fender lip, or have rims that have a tight clearance to the frame. But even then, you are still taking a gamble that the axle you pull needs bearings, seals, and possible axle shafts.
Personally, I would take the car to a 2nd shop. One that specializes in rear axles, and see what they say. The only way to know it really needs axle shafts, is to pull them out and look. Even ones that are silent, might have a ridge worn into them. GM used the wrong gasket from the factory, which staved the outer axle bearings for lube.
