I want to get cylon stop lights for my spoiler (on the imp.) .. does anyone know what might be required. I am good with soldering :devil:.. are there any wires already running through spoiler i can make use of for power and for the signal.. I can probably design the circuitry for the leds to go so under the spoiler it looks like the cylon (battlestar galactica) eyes... :biggrin:
I was thinking to use 2 this Side Emitting "Headlight" LED Strip in 2 foot red one for left and one for right to install under the spoiler I think I have to drill holes thru the spoiler and trunk to pass the wire if you are going to do it get some picture
i might work on some prototype will see what the local electronics store has for industrial level leds, gotta make sure they work in -50 C conditions :giggle:
i am not sure about wiring though if could figure out what volts the brake lights run at and if i can put something in parallel some circuitry using same wires that go to brake lights.
Back in Black
voltage is 12 to 13.8 volts
More like 11.5-15V With the engine running you should never see lower than about 14.5V
anyone got wiring diagram of shots from where the signal can be stripped from to be used in parallel ?
