I replaced the CV axle seal and Hub front drivers side. When I removed the Axle i saw the seal was leaking. Got a new seal but was having a hard time removing the old seal. I did a search here on this forum and found a great way to remove the old seal. Simply drill a hole in the seal keeping in mind you dont damage the hole. Screw a wood screw into it and pull. It worked most excellent .... Until i saw that I missed the hole and the #$%# screw went into the rubber possibly scoring the rim So I checked the hole it had a slight score on the inside. I gave it a touch with some emery and install the seal. Just Tested drove it and trany juice is leaking from the Axle seal. i have no idea what to do about it. I have just started researching this . Hopefully someone could point me in the right direction as far as links and whatnot. Photos of the seal with #8 wood screw and hole beside. My excuse for this is Im an old fart and all that ngoes with it.
