1 - 8 of 8 Posts
Does anyone know if you can customize the offset of a wheel? Or shave the backspacing.
Reason is, when i hit a speed bump my wheels hit the fender. I already fender rolled to. I like my charger rims but i dont like the rubbing on bumps in the rear only.
For more info. They would fit properly but i had rubbing on the calipers so i had to get spacers. So get spacers helped the rubbing on the calipers issue but now i have the rubbing on the fender because of the spacers. REARS ONLY FRONTS ARE FINE.
Or can i shave the caliper?
Update: well i just went ahead and grinded my caliper brackets down a little with my rotary tool, now i am able to take off my spacers. So now i dont have any rub and my rims fit flush with extra space. :eek:k3:
Glad you got it figured out
Reactions: 1impalavision1
Yea had to search other forums to see if it was done before. And there was concerns on shaving the bracket. Which there isnt because camaros and mustangs do it most of the time to run skinnys.
Good info to know :eek:k3:
1 - 8 of 8 Posts
