Got a 04 ss runs a little hot like 210. After that the fans turn on. Wonder if there any mods or suggestions to run a little cooler temps. Since it heat soakes a lot.
Unfortunately these newer cars there is no simple fix, in the old days we could just swap in a cooler temp thermostat but with the GM computers that will simply result in an error that will cut off your A/C as your car thinks it's overheating (yes I'm serious).
That being said I would be mostly concerned with transmission temperatures, so a small trans cooler would help, not so much with the engine temperature but keeping the transmission from running so dang hot.
