ok..my driver side cooling fan is not kicking on ..when i have my ac on the pass side fan turns on,,if jump the relay and the drivers side turns on ..the relays and fuses are all good..i replaced the temp sensor on the water pump it still dose not work..could it be a bad ecm,,,i just dont know what to try next..
The Unscrupulous Lt. Colonel
Primary fan is the passenger side fan and will do most of the work. The secondary fan (driver side) is rarely in use, or used. As long as the primary fan comes on when the temp reaches around 235 degrees (or close to the red). Then you are fine.
Every 2nd Matters
relax. these things act like they are getting super hot, when in reality, they are fine. My primary doesnt come on until the needle in the instrument cluster touches the red. When it does kick on, the thing cools off super fast.
