Okay, so a preface to this: I hit a deer on Halloween and banged up the front end. The fans needed to be replaced and fell apart as soon as I removed them from the engine.
I did replace the fans with similar ones from an Impala in the junkyard, plugged both fans in and bolted them onto the radiator, so everything appears to be hooked up right.
But I tested it the other day and even though it's relatively cold and the thermostat is stuck open, the coolant temp just slowly creeps up, even going past 200-215 without the fans turning on.
Not sure if it could be the fuses (maybe they shorted out during my accident?) or the fan I scavenged was bad (not sure how to tell, it looked fine physically) or another third issue I hadn't even counted upon.
