Based on your previous posts about it the wheel speed sensor code is more than likely a fault in the wiring between the LF hub and the cradle. As for the transmission pressure switch codes both of them usually indicate one or more of the cellophane pads on the switches in the TEHCM, aka TCM and electronic valve body assembly, have failed and the TEHCM will require replacement.
I haven't used them but i have seen that TransGo makes new pads and seals that replace the broken ones. You can find them on ebay or amazon, just search for "transgo 6t65e kit".
