Hi
I dont believe the factory made any stick setups for a 96
So what does anyone do?
Is they something else factory that will interchange or is it only custom fab?
Thanks for your input
Tony
It is a popular mod to swap out the 4L60E for a T56 from and F body. I believe the brake and clutch pedals from an F body will work. GM put a 6 speed in one as an engineering exercise years ago. You might try and Google that and see what you come up with.
Subject: 6-speed conversions as described by the GREAT ONE . . .Mr. "Dal Slabaugh"
Hi guys, below is a complete list of the parts Needed to convert the "b" cars to a camaro 6-speed Trans. List is long but some of you may want to Keep it on file for future.
1. DETERMINATION
2. 12523310 bell housing
3. 12523312 clutch fork
4. 12523315 slave brkt
5. 12523314 pivit bolt
6. 12523313 fork "T" nut
7. 12542549 lever lowr trans.cush.
8. 10215351 control lever
9. 12562940 black leather shift knob
10. 10400399 clutch/brake pedal assemb.
11. 10254529 brake pedal pad
12. 10254528 clutch pedal pad 3817880 clip for mater cyl.to pedal
13. 12337973 f/wheel bolts (6)
14. 10125379 camaro flywheel
15. 12551309 clutch disc
16. 10207027 clutch press.plate
17. 10085246 clutch release brg
18. 12559912 clutch master/slave assemb.
19. 10079898 press.plate bolts (6)
20. 10122690 rever.harness pigtail
21. 10267518 rubber floor boot (to tunnel)
22. 12101899 speedo harness conn.pigtail
23. 14094368 s.starter switch at trans.
24. 88891747 ex.collector gaskets (2)
25. 14061685 roller pilot bearing
26. 12085485 rev.harness connector (trans)
27. 12101857 rev.lockout sol.conn
28. 10198997 trans.to engine bolts (as needed)
...you may not need all of this so just go by what came with the trans,etc. you may go with a later model clutch assemb.but there are various choices, above is just the std. 96 6-speed clutch unit.
