Just thought that I'd post this information in case it helps someone else. It does not seem to be a common issue, which is why I'm posting it (have never heard of anyone else having the issue and even the GM dealer had to call GM for "help" with this one).
The Car:
- 2012 Impala LT w/19k miles.
The problem:
- I kept hearing a "clunk" type noise from the front end when accelerating after coasting (not pressing gas pedal at all). Happened almost every time that I re-applied the gas after coasting and was most noticeable when traveling under 40mpg.
The fix (directly from the dealership paperwork):
- "Checked for PI's and bulletins and found none. Inspected suspension and motor mounts and found all to be tight. Called GM technical assistance and spoke with [name omitted]. Case number [case omitted]. Was instructed to check front axle shaft splines for lack of lubrication and torque. With vehicle on lift and moving front wheels back and forth, the axle shafts are clunking where axle splines meet hub bearing. Lubricated axle splines and re-torqued axle nut to hub bearing. Test drove after repairs and no abnormal noise was heard."
Like I said, hopefully this may help someone else in the future.
Just curious - what would cause this type of situation to occur in the first place at only 19k? Possibly just a lack of lubrication and/or torque @ the factory?
Thanks!
The Car:
The problem:
Thanks!
