· LIFETIME HILLBILLY
I have a question on a 2002 base 3400? At WOT as soon as I step on it I hear a "click-click" occasionally. The sound is coming from the engine compartment. It sounds similar to the click from the engine compartment when you turn on the heat/defrost when the rpm's change, like when I turn on my defroster there is a click and the rpm raises slightly. Anybody have a clue what it is?
air conditioning compressor clutch. at wide open throttle the computer turns off the a/c clutch so you have more power.
:gaah: Didn't thank of that where the a/c was off
I feel like a noob
If the a/c is off and you are not using a defrost setting, it won't be the a/c clutch.
It was the ac clutch I tried without the defrost and it didn't click. My windows always fog up for some reason if its not on
