I noticed a couple of months ago my 2000 Chevy Impala was sputtering a bit when it was started. I tuned it up (plugs, wires, fuel filter) and the problem was not solved. I tried putting Shell V-Power gas which seemed to help but today my car would not start. It would chug a bit but would die out before i could get into gear. I figured it was the fuel pump but the car started eventually. I had made it about 2 miles (rolling through stop signs) before the car died again and did not start. We pushed it about a mile before it started again, where i made it to a garage.
If it started eventually and drove a couple of miles, could it still be the fuel pump?? or could it be a sensor??
thank you for your help
check the catalytic converter, mine went bad in an 02 impala ls a couple months ago. is would start by not run and any high speed about 20mph max.. if it is there is a warrenty on it for 8yrs/80,000 miles that gm will fix for free if it's under that.
