If your engine mounts got loose and the rubber gaskets become spongy, it may affect your engine badly and cause serious mechanical problems. By inspecting and replacing the worn out motor mounts in a timely manner, you ensure the longer lifespan and better operation of your vehicle. If you are looking for a set of high quality rubber or metal engine mounts, make sure to check CARiD.com for replacements. Install them on your Chevy Impala and forget about uncommon noise and vibrations coming from under the hood.
Follow the link to find the full selection of custom-fit engine mounts for your Impala: https://www.carid.com/engine-mounts/
