...is also working fine? the only way a can get it started is from underhood fuse box ,i remove the crank relay (wich is good ) ,and conect a cable from upper right hole to positive battery terminal .Sometimes i have to do this several times ,the motor goes on and after 1 sec shuts off .please help!!! thanks in advice
i agree with the other guy. check the battery cables. i replaced a battery and alternater then a new guy in the shop just cleaned and tightened the positive cable and the car started up and stayed on. every now and then it acts up and won't start or the battery light coes on and the car dies.. i pour some coke on the clamp and it eats away debris. a light banging on the clamp/cable with a rock also gets it started.
