I have a 2006 SS and the tighten gas cap reminder flashes on the dash computer. A few drive cycles later the check engine light comes on. I replaced the gas cap and reset the code and the same thing happens a few days later. The trouble code states there is an emissions leak. Any ideas?
Probably evap canister purge valve, but not certain.
You will need to have the vacuum system of the evap checked. Could be the purge solenoid or a bad hose or even the canister.
