HAve any of you heard of/used the "CarMD" obII scanner? My dad just gave me one and I tried it out and it gave me ABS code C1233 which is
Right Front Wheel Speed Sensor Circuit Open or Shorted. They tell me that if I replace my Electronic Brake Control Module (a $1,592 fix) that it will cure the code. I already had a wheel bearing replacement there to try to rid of the code but it didn't work. I've never gotten this code anywhere else so thats why I am asking about this scanner. Is it fooey?:cool:
Back in Black
Check the wiring on that wheel, could be bad wheel bearing or wiring harness to the wheel. You changed bearing so wiring. Was the code reset?
Thanks guys, I'll check the harness. I know a few people who had a similar issue. It was the harness everytime. Thanks!
