1 - 11 of 11 Posts
Hello guys I'm currently at the car wash washing my 07 ss impala and as I went to crank the car, the car wouldn't crank. The six disc cd changer started changing and the check engine light came on. This is the first time this ever happened to me. As I tried to crank with remote start, it turns over but it want crank at all. Can someone please tell me what's going on? I hope this isn't nothing major
Sent from my ADR6425LVW using AutoGuide.Com Free App
Have you tried to crank with the ignition since trying the remote start? Does it indicate a security issue on the dash? Do you see a vehicle with a wrench on it in the display center? Do you have a second key to try? Maybe your key is done and the immobilizer is preventing it from cranking.
Yes I've tried cranking it since I did it with the remote start. Still nothing, it clicks and yes there is a car with a lock light up on the dashboard, yes I have a extra key and the battery light just came on and the display says battery saver active, service battery charging system, and it also says service theft deterrent system.
I'm about to try to disconnect the battery and see what it does
Thanks for the opinions everyone, I found out that my starter is going bad
Not saying that's necessarily wrong, but how the hell did you get from disconnecting the battery to see if it helps, to bad starter?
Black-magic, I'm happy to see the community jumped in to help. While I can't provide much in the way of DIY advice, I'm happy to help you work with your dealership towards a resolution. Please send me a private message anytime for further assistance.
Best,
Katie
Chevrolet Customer Service
Maybe while he was disconnecting it a dealership fairy showed up and said "magic why you do that for homie, take it in to your nearest dealer they will tell you it's the starter that's bad" .
And that is how he jumped to bad starter conclusion.
:lol: I hope he gets his starter replaced then. If that is the current problem.
1 - 11 of 11 Posts
